Engine parts compatible over the years?
EmilyPip
Post by EmilyPip »
Hi All,
I've got an NC23/NC29 with a few issues at the moment…
The reason I write both model numbers is my frame is a 1990 NC29 series and the engine (obviously not original but in the bike when I bought it) is a 1992/93 NC23E series.
My current engine is at the point of failure/rebuild… I'd prefer to get a another engine for parts however am wondering if anyone knows how much differences there are in between the years/model numbers series?
My current one is in the NC23E-1420001 onwards numbers.. I have one available (albeit 2000kms away) in the NC23E 1300001 - 1310636 series. Unfortunately this engine is incomplete but could have the parts I need if they fit.
Anyone know?
Help SOOOOOOO Much appreciated!
tanuki
Re: Engine parts compatible over the years?
Post by tanuki »
not much changed on the 29 internals through the years....pistons on the later engine were the same as the RVFs but IIRC when I was doing all my engine work it was all interchangable.
Davez29
Bike owned: NC29 forever
Post by Davez29 »
Yep. Nothing changed tween the L & N model engine wise so your good to go. Your best bet is to get a copy of the parts book this will tell you if part numbers are the same. All 29s have engine prefix beginning nc23e.
EmilyPip
Post by EmilyPip »
awesome, this is excellent news people! thanks so much! :)
EmilyPip
Post by EmilyPip »
so then.. according to these numbers, if I attempt to marry up the top end of my NC23E-1420001 series engine with the bottom end of an NC23E-1300001 series I shouldn't have too many problems?
Davez29
Post by Davez29 »
Yes you should be good to go but as a precaution you can download the parts manual and double check the part numbers as needed. Find the parts book in the document library on this site.
