Compression problem+dry fouling on plugs
archeo14
elloo..
My cbr400rr nc29 is runnin on only 2 cylinders that is left cylinders and right cylinders are not working properly...
When i use wet cloth on left exhaust pipes they are very hot n in the same way when i use to both right exhuasts they both are semi hot...
Even i tried using hands on air intake on carbs, left both sucking air strongly n right both none:( ..
Since i am thinking about compression in piston is not good...so how to regain it back...
Change piston rings or piston?
And more over my plugs getting dry fouling even though i bought new air filter n plugs...
Please tell me
Please tell me
dobbslc
Re: Compression problem+dry fouling on plugs
Did it run correctly before this?
It could be the carbs need cleaning and setting up.
You could also have a bad head gasket between those two cylinders or the valves need setting.
Can you do a compression test?
archeo14
No..i didnt done test yet,but soon i am trying compression test...once done ill comeback n let u know...
Moreover,i just buy that ride n trying my level best to make it fine..
Indeed i need to fix its wiring system also..were i can buy that?any suggestions or links..
Another problem is of plugs getting dry fouling everytime (i have new air filter )
How can i fix that...?
Hope you all guys can help me fixing all problems..
Thanks for your kind help..
