Carb balancing vacuum take off
dunkenb
Hi, anybody know what size the vaccum port thingys are (for balancing the carbs ).
Mine have been removed and replaced with bolts for some reason and i was gonna get some replacements from carbtune.
Trouble is they're either 5mm or 6mm ??? And im not sure which is correct
Cheers if anybody knows.
- royster81
Re: Carb balancing vacuum take off
Are you talking about the standard screws?
As standard the bike have screws blocking the holes then you swap out the screws for the brass rods to balancing.
dunkenb
http://www.cmsnl.com/honda-cbr400rrr-nc ... ml#results
It should have parts 5 and 6 as standard , mine has some randome bolts in there.
Was thinking of using these
http://www.ekmpowershop28.com/ekmps/sho ... s-14-p.asp
