water overflow pipe
pauld1
water overflow pipe
had water coming out of the overflow pipe yesterday ,when i turned engine off it stopped ,temp gauge was only half way, please can someone tell me the steps to try first , before taking it to a garage and spending a fortune. cheers
Icemaestro
Re: water bottle overflow pipe
If temp was low I would bet the rad cap :-) cheap fix, I had a similar problem.
pauld1
Re: water overflow pipe
ok i will try that first the rubber seal did look a bit rough, where is the best place to get one i have been on the net but can,t see one advertised , thanks,
Rick Oliver on the forum,
Local Honda dealer
Local bike shop.
www.davidsilverspares.co.uk
www.wemoto.com
www.bitzforbikes.co.uk
www.lings.com
www.cmsnl.com
to name a few.
quote part number 19037-KV3-003 or if they can't find it the newer part number is 19045MZ1621
not cheap though, about 25 quid from David Silvers.
Local Honda dealer
Local bike shop.
www.wemoto.com
www.lings.com
www.cmsnl.com
to name a few.
Icemaestro
...i thought I got mine from the local auto store???(here called repco, supercheap auto)15-20$ (like 8-10 pounds)?i definitely didn't have to buy it online...rad caps are pretty standard items aren't they? just had to match the size, pressure etc
pauld1
thanks for part number, easy to find now.
hence why i said local bike shop in my list.Icemaestro wrote:...i thought I got mine from the local auto store???(here called repco, supercheap auto)15-20$ (like 8-10 pounds)?i definitely didn't have to buy it online...rad caps are pretty standard items aren't they? just had to match the size, pressure etc
You can get some after-market parts as long as the pressure and size is the same.
The partnumber quotes for the genuine Honda part.
