Starting problem
chrish862013
Starting problem
Hi guys need help turned the key neutral and oil light come on the exup weeps and the pump goes but theres a ticking sound yes like the one from a clock i followed it to this little black box which i believe is the main relay.
Anyway i hit the starter button and nothing not a peep.
Any ideas
Any ideas
Re: Starting problem
There should be a code on it ... type that into the web and see what you get ?
chrish862013
No code i suspect it might of been a cheap chinese replacement does the 600 one fit a 3tj
Doubt it was Chinese just an old one that the paint rubbed off of. The 600 should fit.
chrish862013
Got one from a 600 same number on the side
chrish862013
Fzr 400 rr main relay ticking: http://youtu.be/nzrc3WpTeKE
This is what happens the start but does nothing the exup does nothing but when i remove the relay the ticking goes and the exup moves
Does anyvone want it for £350 ha
Is that the relay you just put in or the old one ?
chrish862013
The new one does the same soooooo anoying when i take the relay off and turn the key on i here the weep weep of the exup and when the relays connected. The instrument panel lights come on but none of the lights work and nothing from the start button, fuel pump and exup
Sounds like a protection circuit to me, like a kill switch.
Try shorting out the side stand switch first.
Then the clutch switch and then the neutral sensor.
Go to the point in the loom where they plug in and bridge the wires
chrish862013
Any pointers where they are and the best way to get to them
