Jack-up kit fitted: the spring shock is touching the swing a
Hi guys,
I've just mount my jack-up kit to fit a 17" rear wheel on my french 30.
Once the bike on its wheels I noticed that the spring is touching the swing arm :-S
Actually, the linkage brings the feet of the shock (I'm not sure you use this word in English...) to the front.
I can ear the spring hurting the arm when the back is going up after pushing down it.
I've tested it with 2 rebuilt rear shocks with the same results. The both measure 310mm from eye to eye.
I may have made a mistake with thee linkage but I can't see which one... I guess the link which 3 eyes do not have the same thickness on each eye. So I don't know how I could mount it the wrong way.
Any idea?
I could take some pictures if it helps.
Thanks for your help,
Romain
Any idea?
Romain
Re: Jack-up kit fitted: the spring shock is touching the swi
Strange.
What "Kit" are you using to raise the wheel up? What shock are you using?
Pictures will be good, it can help :)
sounds like either the wrong kit or something isnt fitted properly.
Hi Neosophist,
I'm using Rick Oliver's kit with a stock and a White Power shock. The both were fitted on 2 VFR 400 with 18" rear wheel.
I'll have a look to the bike this morning and take some pictures.
