Bicycle / pedal bike speedo
- Tim400GB
Anyone here use a bicycle pedal bike speedo on their nc30?
It's for my daytime mot track bike.
I've got a sigma one (with a wire to the pick up) but trying to find a suitable place for the magnet and pick up is proving to be a nightmare
There's just so little space!
- Yakama
Re: Bicycle / pedal bike speedo
I'm sure I've seen ones before where people have but the magnet in where the brake disc bobbins are but obviously depends on the size of the magnet
- Yakama
Along the lines of this, you get the idea.
- Tim400GB
That's not a bad idea.
Need to buy a small round magnet now
I got a load here if you want one mate, i bought them to go inside the kawasaki's disc bolts but they should fit the NC aswell
- Tim400GB
what diameter are they DM? would they fit inside the disk bobbins?
Doubt it I'll measure them later
- Tim400GB
- EsKee
Calibrate it with a sat-nav!! I measured my tyre diameter to the the 'thou' when I installed mine . . . ended up reading nearly 20 mph over at true(sat-nav) 70mph . . .
- DocV400
- Bike owned: 1200 Bandit ~ NC30 ~ Italjet
Magnet and pick-up doesn't have to go on the front wheel of course.
I put my magnet on a small tab held under one of the Sprocket nuts, and mounted the pick-up on a small bracket fixed to the Chain-Guard mounting bolt.
That way, you can hide the wire easily (I fixed mine to the Brake line), and you don't have to allow for Fork travel.
