Fuel pump wiring NC23
jonhunt
- Bike owned: Kawasaki Z1a,Honda NC23j
Looks like at some point the fuel pump relay has been taken off my bike. I'm not sure how the wiring should look. Currently the pump plugs into a flying lead (Y shaped) that joins to two points on the main harness. This separate lead has been cut about somewhat & I'm not even sure it should be there. If someone has a pic. of the set up in this area it would be a great help
OK sorted now with gratefully recieved help from GFracing. Hopefully this will sort the fuelling issue too
