fitting crash bungs
missinNZ
fitting crash bungs
Post by missinNZ »
where is the best place on a 29 for these? (a pic if your ve got one), im looking at getting a set that come as just the bung and have seen that all is needed is an m10 1.25" thru bolt, is this a good idea. they are 50mm.
leopard_pagan
Bike owned: CBR400/600 Fighter
Re: fitting crash bungs
Post by leopard_pagan »
1 bolt is longer than the other. when i needed to replace the longest bolt. i went to a nuts n blots place and they said it was a custom made bolt and they could not get them in.
its better to buy the whole kit...
you also want to consider drilling a larger hole so the panel slips over the widest part of the bung for easy maintenance access.
superlite
Bike owned: TLS, LB80 x 2
Post by superlite »
It is difficult to get the bolts! Your average fastener joint doesn't stock them: "Nah mate, they're fancy Japanese bolts". I ended up re-tapping mine to take a standard bolt - did the job.
'Take it to the Back'
leopard_pagan
just get the WHOLE kit and be done with it...
