NC29 radiator fan wiring issue.
Crazy_German
Bike owned: CBR 400 RR NC29
Post by Crazy_German »
Hi folks,
As the title says, I got a problem with the wiring of the radiator fan. My whole loom was stripped down and the complette bike was dismounted for overhauling everything.
And now I got the two cables for the rad fan (black/blue + and green which is ground) I got an haynes manual but i´m just to dumb I quess cause I don´t get the schematic fpr the correct wiring of the fan and the coolant temp switch.
So where do I have to mount the cable with the cable eye? the ground cable from the fan have to be on the coolant switch right? and the + Cable belongs to the black/blue from the main loom right?
On may 30th I got my deadline because than my bike gets to my honda dealer for synchronizing the carbs an than i have to make my first 1000 miles to carefully running in the engine!
Davez29
Bike owned: NC29 forever
Re: NC29 radiator fan wiring issue.
Post by Davez29 »
From memory, so maybe wrong but the ground with the cable eye just fits to one of the three fan cover bolts. The temp sender wires block fits to the fan cover. I will check tonight to be sure on everything.
Crazy_German
Hi Durka,
Thanks for the reply, do you found time to have a closer look anto your bike?
Luke400
Post by Luke400 »
I'm going to be removing my rad and fan hopefully today so can get some pis of wiring if that's any help?
Luke
Crazy_German
Hi Luke,
thats would be very helpfull, thnak you!
Davez29
Post by Davez29 »
Sorry I did look then forgot to reply. Basically the wire from the loom, fan and thermostat all plug together and mounted on the L shaped bracket on the left of the fan cover. The earth fits on one of the fan cover mounting bolts, the long wire going to your thermostat is also clipped to the outer left of your radiator. Sorry I didnt take pictures but looks like the other poster will.
Luke400
Post by Luke400 »
I removed the rad only to find it was not wired up :/ the bike was recently brought as a project, I have the fun of rewiring now.
Sorry I couldn't help
Luke
