The weight list.
The weight list.
So here it is again!
Please feel free to tell how much a standard RVF fork and Dymag magnesium wheels are.
Object Weight
Forks and things connected to them
Top triple clamp 465
Lower triple clamp (nc30) 1495
Front fender 421
Clip ons standard 798
Clip ons NC30 aprox. 1900
Woodcraft clip ons 696
Woodcraft clip ons carbon handlebar 446
Honda RS250 front end w. triple clamps
and axle 7360
late type NC30 forks, only the fork legs 7100
Main frame and things attached to it
Side stand 836
Meter fairing stay 427
TYGA meter fairing stay 210
Meter 1025
Rubber shield front 67
Rubber shield rear 75
Foot peg complete R 684
Foot peg complete L 718
Foot peg complete R Rick Oliver 480
Foot peg complete L Rick Oliver 535
Tank empty complete 5460g
22 litre alloy tank empty, complete 3650g
Standard fuel filler cap, complete 380g
BikeTech alloy screw type cap, complete 185g
Fuel tank noice shield
Honda upper radiator 682
HRC upper radiator 1041
Rick Oliver upper radiator 900
Rick Oliver lower radiator 910
Rear frame and things attached to it
Passenger foot peg R 269
Passenger foot peg L 385
Water expansion tank 325
Water expansion tank Rick Oliver 49
Tool kit 782
Rear brake reservoair 60
Rear brake reservoair Brembo from RO 15
Seat incl. Lights Plasic 3 parts + light2030
Non standard LED light 57
Rider seat pad 561
Pillion seat pad 812
Rear frame Std 3300
Rear frame alu one off 740
Rear undertray incl. indicators 1490
Speedfiber RSW seat in GRP 1100
Svingarm and things attached to it
Sving arm spacer Honda 215
Sving arm spacer Alu 76
Rear disc 992
Rear disc aluminium one off 330
Rear brake caliper 885
Rear wheel axle 1862
Rear wheel axle HRC style 1440
Rear axle nut 90
Rear axle nut ProBolt Ti 48
Suspension dogbone link NC30 647
Rear shock absorber 3052
Rear shock absorber Aprilia RS250 3200
Rear shock absorber Ohlins 2000
Rear shock absorber Ohlins from a GSXR thou 3210
Rear shock absorber Nitron sport 2300
Rear shock absorber Hyperpro 3600
Rear shock springs (to compare relative weigh, spring rate and leght should be taken into account)
showa nc35 1108 gr (Free length 188mm, 140Nw mm??)
öhlins 1106gr (Free length 147mm, 150Nwmm)
Wilbers 1010gr (Free length 150mm, 120Nwmm)
RCS 650gr (Free length 147mm, 120Nwmm) Titanium coil, öhlins fit
Chain guard 223
Rear sprocket standard 38T 737
Rear sprocket Renthal 40T 200
Chain DID 525 VM 1687
Chain DID 520 ERV2 1670
Wheels and front brake
Front rim No discs or tyre 4200
Front brake discs. Both incl bolts 2664
Front brake calipers
Front tire 3300
Rear rim 4200
3-spoke Dymag aprox. 3200
Rear tire 6000
Galfer Wave Rotors part # DF027CW 2500
Fairing and things attached to it
Lights 1165
Fairing upper Incl. flash lights 1345
Fairing upper side left 298
Fairing upper side right 298
Fairing lower side right 884
Fairing lower side left 737
Fairing lower triangle 340
Speedfiber RSW fairing 2600
Electrics
Battery YT12A 3500
Battery YTR4 1155
Battery A123 Speedcell Powerpack 2.3 Ah from Durbahn 370
Battery box/holder one off stainless 156
Wire loom 1450
Cut down loom (race) 577
NC30 CDI 163
NC35 HRC CDI 256
Engine and things related
Engine. No oil or carbs 55800
Carbs 3500
Keihin FCR set 2770
HRC air tray 263
Air box top incl. Filter 1060
Air box top HRC incl. Pipercross filter 400
Front sprocket 15T standard 225
Front sprocket 15T Renthal 186
Front sprocket 14T Renthal 168
Starter clutch 794
Alternator silencer 102
Alternator rotor RVF 1820
Alternator rotor GSXR 1000 K5 610
Clutch cover w/ dipstick 1066
Exhaust
Front exhaust down pipes 1450
Rear exhaust manifold 858
Rear exhaust pipes 3500
Heat shield exhaust 298
Honda Exhaust end can 2704
HRC Exhaust end can 1718
ART alu Exhaust end can 2370
TYGA carbon Exhaust end can 1497
TYGA Twin Stack alu mufflers 900g each. 1800
Honda full system without endcan 6106
HRC full system without endcan 4942
Ethos full system without end can 3550
Ethos end can 1712
TYGA full system without end can 3172
hiperform exhaust with megaphone style
end can at 4928
I would really like if we can keep this list alive.
Object Weight
Front fender 421
and axle 7360
Side stand 836
Meter 1025
Tool kit 782
Rider seat pad 561
Rear frame Std 3300
Rear disc 992
Rear axle nut 90
Chain guard 223
Front tire 3300
Rear rim 4200
Rear tire 6000
Lights 1165
Electrics
Battery YT12A 3500
Battery YTR4 1155
Wire loom 1450
NC30 CDI 163
NC35 HRC CDI 256
Carbs 3500
Keihin FCR set 2770
HRC air tray 263
Starter clutch 794
Exhaust
Ethos end can 1712
end can at 4928
- Bike owned: nc23, 750/k4
Re: The weight list.
THis list is reet good methinks -
what id really like to know is whos got the lightest NC30/35 here?? Both Road and Track - ( their dyno printouts would be nice..... mm....)
Mine vill be on the scales in the beginning of next week. I hope for 160 kg with 15 litres of fuel. That is 20 kg less than standard.
Kay
Kay
Nice one Rallykay
I got nowt on my bike worth weighing..apart from some alloy bars that I got from Rick?
This sort of list and the dedication to HRC mods on this site makes me really think of gettin an NC30 as a long term 'thing'... (i have to consider this when im supposedly emigrating to Singapore next month ..)
I think someone needs to total the maximal loss of stuff,( a chart with a ~~ perhaps ~~ with a cash- o -romitor - indicator of wallet suicide cash per gram ) But stuff like the rear subfrme in ally choppin of 2.5 kilo -2 kilo loss from a alloy tank an cap..
1.5 kilos per clippon lost - this cant be true..(~!). shirly .. .??? yess i go round with 3 bags of sugar tied to me bars...
we had ti hollow wheel spindles in or Race ped - inherited from another team who spun them up at work ( 'some place' called Rolls Royce ) - thay were mind blowingly light.... just totally speech inhibbiting
does anyone have weights for the many alternative wheels which are used on NC30's?
--edit: oh, I see you already asked, right at the top...
--what about the weight of Rick Oliver's axle for the VFR750 wheel kit?
was interested to see that the battery could be swapped for a lighter one.so looked up battery YTR4.And it has spade connectors instead of the bolts for the battery connection.Was just wanting to know if anybody had tried changing it and did you have any problems with it?cheers.
Regarding the battery.
Yes the spades ain´t a optimal connection. I have to squeese mine "female connectors" (no i don´t know what they are called!!!) together now and then and make shure they are proper clean and lubed with vaseline (this reply sounds bad!)
Other than that it works fine.
Kay
Kay
Updated with the weight of my new ohlin shock. A heavy bugger unfortunaly. My wallet will have a hard time forgiving me when i by that titanium spring!
Does anyone know from what bike the 2000 gr ohlin came from?
Sneaky little bump for us fettlers out there trying to make our bikes lighter..
