GK76A Vacuum Port for Carb Sync?
Hi guys,
im looking for the Vacuum ports to screw in the brass connectors from the Carburettor Syncronizer pictured below:-
Ive been told they are on the engine below the cylinders where the carb boots would fit on but i cant seem to find anything...
i was starting to question whether this carb sync kit would work with this bike but this youtube video shows it working but unfortunately doesnt show where its connect on the bike
Can anyone help me?
Thanx in advance!
Can anyone help me?
Thanx in advance!
- Bike owned: 1990 gk76a
Re: GK76A Vacuum Port for Carb Sync?
You dont need the brass screw in adaptors just take off the rubber covers on the carb tops [black plastic top part of carbs]
and push the pipes on that go to your gauges .hope this helps
Forgot to say one has a pipe running to the fuel tap to operate the vacuum on off
thanx panda!
could you confirm that these are the ports.
Probably slightly different to your bike as mine doesn't have a pipe running to the fuel tap...although it seems to have a broken port which has been patched up by silicon...
Yep thats the ones .might be worth looking at your fuel tap probably has to be on prime to get fuel flow without a vacuum feed to make the tap open on the on position or reserve.
thanx again panda! I will look at the fuel tap and might post another photo for help!
That carb-sync video seemed strange to me. It seems wrong that the guy who is doing the sync has already connected the manometer array to the individual carb vacuum ports but he's still messing with the calibration valves on the lines.
I'm not an expert on these things but I thought that the calibration valve setup of the manometer array was supposed to be done on just one single cylinder's vacuum port while the engine idles at a known rpm. Each input line is connected in turn to that single cylinder at the same rpm and the calibration valve is adjusted so that each manometer registers the same. That way when you connect the manometer array to the individual cylinders you know they are all "referenced" at the same baseline.
SevenThreeSeven wrote:That carb-sync video seemed strange to me. It seems wrong that the guy who is doing the sync has already connected the manometer array to the individual carb vacuum ports but he's still messing with the calibration valves on the lines.
You are correct, but in the vid. it is the damping he is faffing with not the calibration.
does anyone have the part number for the 2 fuel hoses?
