Difference between 87/89 nc24
Typarr
Post by Typarr »
I've recently started work on my nc24 and I'm running I to trouble the reg says 89 but when I check the numbers on the frame it matches up to 87 numbers is there any obvious difference between the two years I can def say yep that's the year of the bike
Thanks so much
Re: Difference between 87/89 nc24
No difference that makes any difference
Typarr wrote:I've recently started work on my nc24 and I'm running I to trouble the reg says 89 but when I check the numbers on the frame it matches up to 87 numbers is there any obvious difference between the two years I can def say yep that's the year of the bike
Thanks so much
Well they only made the NC24 in 1987 and 1988, the differences between the two years were minimal.
They were never made for the UK Market so probably when it was registered. Wouldn't worry about it, as above, the info will be the same.
