HELP nc29
kstation
HELP nc29
Right people I need some help as bike won't start turn key lights come on press start button starter relay (new) clicks and dash lights go out they come back on after about 30 seconds but then the same happens every time start button is pressed battery showing about 12.6 volts hope people can help because I'm stump thanks
- Davez29
- Bike owned: NC29 forever
Re: HELP nc29
Maybe a flat or duff battery. These bikes will be very hard to start on worn batteries, it does not take many presses of the starter to lose sufficient power needed for a good start. Charge it and see if it quickly loses charge while starting. If it does best replace before looking further into problems. Also if its not been started in a while it could be a fact to consider as these bikes are very cold blooded and need some pampering to get them running again.
Gimly56
- Bike owned: NC29 CBR400RR
Re: HELP nc29
I'd check the starter solenoid/relay. It's situated just below the seat and has a green top. Mine was kaput and my bike would just click when I tried to start it with a new battery.
