Valve shim Calculation
Posted: Sun Apr 06, 2014 9:07 pm
Hi all
While my carbs were off having some minor work done I decided that I would have a go at checking my valve clearances after reading the guide on here, It didnt look to scary. Seeing the figures I was getting from the rear cylinders I chicken out of doing the fronts and wanted to get these calculations checked.
By the way I did do a quick exel spreadsheet that does all the maths for you(layout is as is above), if anyone wants or needs a copy give me a shout unless the admins can post it some how....
