Slow Returning to Idle
Rascal
HI Guys,
I've just fired up my bike for the fist time since an overhaul. I've had the cards ultrasonically cleaned and they're immaculate inside an out. I've got a problem where the bike doesn't seem to want to return to idle after being revved and the revs seem to hang a bit.
(I'll post a video later)
I've confirmed that there are no air leaks also my carb rubbers are new. The bike just doesn't seem to be running quite right. The only thing that remains to be done is balance the carbs. Would this be a potential reason to my symptoms, unbalanced carbs?
dobbslc
Re: Slow Returning to Idle
Unbalanced carbs can cause a bit of that but also if they've been rebuilt check the pilot screws settings, I fine that an extra 1/4 - 1/2 turn out can make for a much crisper response.
Rascal
Thanks - I'm currently at the 2.25 turns on my pilot screws on all carbs. Running 118/120 jets.
Here's a vid of the sloppy revs: http://youtu.be/zq-e3ENO58Q
Just to add I'm running a full Tyga system and have fitted a new air filter.
Icemaestro
Mine does the same thing... Interested to know what fixes it - do you go to 2 turns or 2 1/2 turns?
- vfrman
- Bike owned: NC30, 1098s
Do you have the stock air box on?
- benny
throttle cable sticking, thats what did it to me when i had the carbs off. Check your routing.
DM104 for the road race team.
arsey30
- Bike owned: ftr223 650 bros
Yes, check throttle snaps shut, if not loosen cable lock nut near throttle housing a put more free play into cable.
If carbs well out of balance, then throttle stop needs to be wound in more than normal to achieve correct tick over speed [not running on all 4] which tends to make revs hang on closed throttle.
Rascal
Yes running stock airbox. I have noticed like suggested that my throttle stop/ idle control is wound in more. I'll also look at my cable routing and report back. I'm thinking of going 120/122 jets but I suppose this won't make much difference to the hanging revs.
Is it still worth turning out my pilot screws another 1/4 turn?
arsey30
Main jets operate from 3/4 to full throttle, pilots from closed [tick over] to between 1/8 and 1/4.
Richening the pilot screws may improve the hanging rev problem but will just be masking the fault.
- benny
As arsey said check the throttle snaps shut, ie the bike doesn't need to be running just open the throttle then let go and it should quickly snap closed.
