Rear shock NC29
- mattiec321
- Bike owned: GSXR1000K7 Monster HondaPX50
Rear shock NC29
Hi guys
The shock on the 29 is desperate for a swap or rebuild. I have heard that a cbr6 shock is a straight swap. Would one from a 97 model fit with no issues? thanks all
dunkenb
Re: Rear shock NC29
http://www.gfracinguk.com/rear-shock-ki ... p-121.html this could be what you're after ??
- mattiec321
Re: Rear shock NC29
Yeah that's awesome and all but I don't have the £120 spare. I have found one at around £30 straight from a 97 600 I just need to know if it is a straight fit and that I don't have to get spacers made up
dunkenb
Re: Rear shock NC29
You need to cut a small notch into the linkage that bolts to the bottom of the shock to clear the lower damping adjuster . Its on the side of the shock body where the nc29 one is on the top . Just take out the linkage and bolt it to the shock then you can see where you need to file or saw it . Dead easy .
