K&N oil filter clearance
GlenR
Howdy,
Changed oil today and the local parts place only had the K&N filter with the nut on the end. Annoyingly, it hits the radiator fan shroud so i had to space the whole lot out a little bit with an extension on the lower mount.
Is this a common thing? or perhaps the lower radiator mount is bent? It clears the fairings and all that when swung foward a little (about 14mm more foward) so just wondering if people have done this before and if there is anything to worry about having done so?
Cheers!
Cheers!
Tornado
Re: K&N oil filter clearance
I had the same issue with a K&N oil filter on the wife's RVF. I ground the nut off and all is well!
Hope this helps!
Hope this helps!
