fork springs
hughc62
fork springs
Hi there does anybody know if there is stiffer fork springs available for an NC39 V Tech
ybanrab
Re: fork springs
I'm afraid I don't, but if you do find anything, do post back here. I've got a '99 NC39 and I've got to do the fork seals soon, so I'll measure the sizes of the existing springs when I do it, in case that points to what sizes may fit
Barny
Barny
Re: fork springs
Of course there will be springs for it - you need to know the current forks rate and free length and you can then go from there.
ybanrab
Re: fork springs
I've just done the fork springs on my '99 Spec 1 NC39 and here's the dimensions in case you can make use of them. The forks on the earlier VTEC bikes look different to those before and after, so if you've got a later one, this may not apply to you.
Stanchions: 41mm Diameter, 612mm length
Main Spring:
323mm length, 35.5mm OD, 26.3mm ID
Spacer:
200mm length, 24mm OD, 32.6 ID
Piston:
210mm long
The fork lowers look suspiciously similar to the ones fitted to Fireblades from about 95 to 99 or thereabouts. I'm going to do a bit more research and see if there's any chance I can combine the two :)
thanks
Barny
Main Spring:
Spacer:
Piston:
210mm long
thanks
Barny
