Voltmeter wiring
Repsolnc30
Bike owned: Zx636 B1h, vfr400 nc30, rgv250
Voltmeter wiring
Post by Repsolnc30 »
Hi have just bought the koso voltmeter to keep an eye on the voltage and charging system, I was going to take the switch live from the headlight and then other cable to earth, where would be the nearest earth at the front of the bike ?
bikemonkey
Re: Voltmeter wiring
Post by bikemonkey »
Left hand side, just underneath where the mid panel meets the lower :peace:
Malc
Bike owned: NC35, 5SL, 3XV, 2MA
Post by Malc »
Repsolnc30 wrote:Hi have just bought the koso voltmeter to keep an eye on the voltage and charging system, I was going to take the switch live from the headlight and then other cable to earth, where would be the nearest earth at the front of the bike ?
The whole bike is an earth. Bolt your earth to any bit of metal that is connected to the main frame. You don't need to use a specific earth point. You can in effect have an earth maybe one or two inches long should mounting position of the meter allow it.
Bike owned: VFR400
Post by magg »
Wire the voltmeter directly across the battery.
dgunthor
Post by dgunthor »
i added a cigarette lighter socket to mine and have a voltmeter that plugs into it - can always use it as a phone charger / satnav power supply then
