CB400 Pilot screw and hydro gas settings
Bigdave982
Can anyone tell me the fuel pilot screw settings and hydro gas range readings for my '92 CB400?
I'm going to balance the Carbs and need to know the base settings :0)
Cheers, Dave
Cheers, Dave
superv500
- Bike owned: CB400, CBR900RRW, CB750
Re: CB400 Pilot screw and hydro gas settings
Set mine 2 1/2 out.
Unsure what you mean about hyrdo settings...
Bigdave982
It's the butterfly setting, you adjust them and balance the carbs.
The reading provided by the carb balancer measure in Hg, "Hydro gas" no idea what it truly means but Haynes manuals always have the levels in for this reason. Sadly I can't nip out and get one for my bike as we all know!
Ben_OB1
- Bike owned: NC35, CB100F2 Supersport
Bigdave982 wrote:It's the butterfly setting, you adjust them and balance the carbs.
ROFLMAO
Hg is the chemical symbol for Mercury. Vacuum is measured in inches (or centimeters/millimeters) of mercury, as this is the old scale used in manometers. One inch of Mercury is just less than 0.5 PSI or 34 millibar.
My RVF was about 200 mm.Hg at idle for each cylinder when I last sync'd the carbies, I would expect the CB400 to be similar.
http://www.mcp.com.au/carbtune/
Ben.
Bigdave982
Someone told me that's what it meant. I'd no idea prior to that as no manuals have even explained it.
Ben_OB1
Hehe no worries. The actual values of vacuum aren't really that important so long as all cylinders are drawing the same. There should be some good reading on the carb tune website. Sorry about my laughter earlier, I was mostly laughing at myself for trying to understand what the Hydrogas value was... Slaps forehead!Bigdave982 wrote:Someone told me that's what it meant. I'd no idea prior to that as no manuals have even explained it.
Ben
Superjack44
- Bike owned: 1CB400 SF 1 VFR800 1 Moto Guzz
If it helps this is how I set my carbs up from scratch after dismantling and cleaning all four carbs I inserted a half thousandth feeler guage under the butterflies from the head side and adjusted the screws until I could just feel a very slight resistance as I pulled on the feeler this gave a good base setting as I could then adjust the tickover to then accomodate the revs to suit the carbtune (Manometer) and then adjust each carb to get a good balance.
As you adjust one its possible it may throw out one or more of the others just keep checking the butterflies with the feeler guage
For the mixture settings I used a gunsons colourtune to adjust the mixture settings it was a bit fiddly but it worked for me.
I think I first set them to about 2 turns out from fully in.
