nc30-35 linkage
richyrd5
Regular Member
nc30-35 linkage
Post by richyrd5 »
Ive the 35 linkage on my 30,does this raise the ride height,or is it taller with the 30 one on.tia.
bikemonkey
Re: nc30-35 linkage
Post by bikemonkey »
It raises the rear :peace:
richyrd5
Regular Member
Re: nc30-35 linkage
Post by richyrd5 »
Thats wat i thought,but it sits pretty low,god knows wat it was like with the 30 linkage in!cheers tho chap :peace:
williamshatnerspants
Bike owned: '89 NC30
Re: nc30-35 linkage
Post by williamshatnerspants »
I just did mine and the ride height at the rear (measured form ground to the upper tab on the plastic coolant reservoir) went from 690mm (tired old shock and std NC30 linkage) to 720mm (rebuilt shock and shortened linkage)
richyrd5
Regular Member
Re: nc30-35 linkage
Post by richyrd5 »
Wow,best i get the preload spanner out.!! :whistle:
Cammo
Re: nc30-35 linkage
Post by Cammo »
Check that your eccentric hub is not upside down too, this will lower the ride height quite dramatically.
