Choke Cable Position
Rascal
Post by Rascal »
Hi I'm just re-installing my carbs and have a question about the choke cable arm. When the choke is off should the choke arm be all the way back towards the left hand side of the bike or about half way along? I'm assuming that half way is the off position rather than 50% of choke.
Here's a picture of the choke in the off position:
And this is how much the sliders/plundgers are out in this position:
Image Image
Would someone let me know if this is correct? It's one thing i didn't get a pic of before removing them.
It's an RO choke conversion by the way, not that it should make any difference I suppose
:rocks:
RoninZX-10R
Bike owned: NC35 racebike, ZX10R roadbike
Re: Choke Cable Position
Post by RoninZX-10R »
I'll have to check my bike when I get home tonight after work, but from memory the choke cable arm should be a lot further to the left than what yours is, and the plungers should be fully seated, yours looks like they're about half way out.
Can you physically move the choke cable arm further to the left, or is that as far as the cable will allow it to travel?
Rascal
Post by Rascal »
Thats as much un-sheethed cable there is this is with the RO choke fully closed and therefore the arm can't travel back any further.
I could clamp the cable futher over to the left but it won't be clamped on the metal stop as it is in the pics.
Has anyone else fitted the yoke mounted choke?
Cammo
Post by Cammo »
I fitted one of Rick's choke conversions and don't remember having issues (but may have!).
That said, just clamp the cable further down. There shouldn't be a problem if you don't overtighten it (perhaps use some light threadlock on the screw).
bikemonkey
Post by bikemonkey »
As Cammo said, just clamp it further down, I had to and it makes no difference.
The amount of bare cable available isn't long enough but it's no biggie :peace:
Rascal
Post by Rascal »
Ok guys thanks for the help, all done.
bighug
it loks like the choke plungers are being pulled out a little?
All you need to do is make sure that when fully off the arm isnt engaging the plungers at all.
Rascal
Post by Rascal »
Plungers are all the way in when choke is closed now. Although I don't get their full travel out with the new choke open full.
Cammo
Post by Cammo »
I wouldn't worry, the standard setup doesn't pull them out all the way. Most of their action is in the initial movement.
