Are early NC30 fork stantions the same as later fork
Posted: Mon Oct 27, 2008 6:28 pm
by katana
stantions?
Are they interchangeable?
The later stantions seem to have holes (at the bottom) in a different place so are they interchangeable ie an early stantion in one leg and a late stantion in the other? This is with the later fully adjustable cartridge of course.
Re: Are early NC30 fork stantions the same as later fork
Posted: Mon Oct 27, 2008 6:31 pm
by hannakournikova
nope, although the lowers are.
Posted: Mon Oct 27, 2008 6:41 pm
I'm gonna say No too but it depends on how early you mean by early ^_^
>91 all use the same forks as far as im aware.
Posted: Mon Oct 27, 2008 7:01 pm
by katana
Well one set of forks are preload only, whilst the other forks are pre load and adjustable tops.
Posted: Mon Oct 27, 2008 7:21 pm
by deano
Im gonna say yes because I have actually done this.
All you need to do is remove the rubber ring at the bottom of the stantion and then file the 4 tabs down a few mm in order to let the damping internals to fit.
Very easy mod. I posted this mod a few years ago on here but knowone really cared. older forks go for alot less than the later forks.
Posted: Mon Oct 27, 2008 9:32 pm
by katana
deano wrote:Im gonna say yes because I have actually done this.
Can you direct me to the post as I can't seem to find it.
Thank you
Posted: Tue Oct 28, 2008 8:54 pm
by deano
well not necessaily this site but the older .co.uk i did.
but its very easy to do. take the stantions out look at the bottom of the tubes and you will see a rubber ring which needs to be taken out i used a drill. then with the 4 prongs that are holding the ring in place they need to be filed down a few mm so that the newer internals are able to slide throught and for the ebound spring to seat on top of the prongs.
