400 3tj1
				dobbslc
Re: 400 3tj1
I'll check my parts book for you.
				rockTJ
Re: 400 3tj1
Its part number 3TJ-22151-00.  I am pretty sure it is still available new.  Mine cost just over £38 when I got it about a year and a half ago.
If you can get a PDF copy of the parts book (which is available here in the docs section?) it's well worth it as the parts diagrams are very good quality.
Chris
Chris
				chris6409
Re: 400 3tj1
Thanks for tge part number im wondering if the other fzr 400's have the same part as the part number is the same apart from the 3tj bit
				rockTJ
Re: 400 3tj1
They are probably not the same.  The first three digits refer to the model of bike the part is intended for, the next refer to the part itself and the rest are for revised numbers, like 00-00 is superceded by 00-01 etc.  This is to take into account differences on the same model bike ie 3TJ1 and 3TJ2 or 3TJ6.
I have the parts books for quite a few yammies. All of the std exhaust cans are XXX-14710-00, but they obviously don't fit other bikes!
Chris
Chris
- Kayla850
- Bike owned: Sunn Tzar S2
Re: 400 3tj1
No, you're right, they're not the same. You need a 3TJ chain rubber to fit a 3TJ swingarm.rockTJ wrote:They are probably not the same.
They tend not to come up second hand (ie cheap) much, I ended up buying two for the last couple of 3TJs we had. £40 each isn't a massive amount to pull out considering it'll probably last another 20-odd years and twenty thousand miles!
www.projection-racing.com
www.pjcfasteners.com
				chris6409
Re: 400 3tj1
Will one from a 1wg fit a 3tj
				rockTJ
Re: 400 3tj1
NO!!
				chris6409
Re: 400 3tj1
Ah well dont suppose anyone has a 2nd hand one
