??? few odd questions
Posted: Sun Jan 26, 2014 11:35 pm
by veefa
Question, Crankcase breather hose/ should it have a bit of fuel in it....I have never noticed until now?
Q, under the exhaust there is a little hole / after a blat yesterday I noticed what seems to be water dripping from it, about half a tea spoon in total dripping for around 5/mins or so after turning off bike???? is this a stock thing iv just never noticed b4 am I right to presume this is to let out condensation???.
I let the bike get up in temp b4 every ride however yesterday it had no balls it wouldn't even get up my driveway( steep- but never had any dramas b4 then, I removed the tank and drained the fuel thinking it might have gone off/- the last 100ml of fuel to come out was very cloudy ( water in fuel was my guess)- so I cleaned out the tank completely of all fuel and small amount of debris and replaced with fresh fuel, that's when I spotted the crankcase hose has a slight crack on one side and a bit of fuel dribbled out/ hence the questions.
the exhaust hole looks factory as the pipe is orig and in mint cond.
my other nc's have after market exhaust and don't seem to have this hole..!
cheers to all whome can help with my small brain questions, im stumped.
I did try finding answers in the workshop section to no avail
cheers again ladies and gents
VEEFA
Re: ??? few odd questions
Posted: Mon Jan 27, 2014 1:05 am
by VFRkieran
Crankcase breather as in the one on top of the rear rocker that is connected to the airbox? If so that shouldnt have any fuel in it, maybe some running back in from the airbox if your running rich but i doubt that, could be petrol thats got down into the sump somehow, do you have the HRC fuel tap mod?
The exhaust hole if on your end can should be there and thats probably just condensation dripping out, its worse on these with the stainless pipes, slight change one of your seams has a little hole in letting more water in if the bike is stored outside in the rain.
Posted: Mon Jan 27, 2014 1:46 am
by veefa
Cheers kieran,
Taking a few pics now .
Bike starts first time everytime . Except on this occasion. New fuel now and seems to run better . The fuel I took out was pink and didn't smell to good - for fuel that is ..
Re hole in lower sect / under side of pipe . That makes sense.
Posted: Mon Jan 27, 2014 2:20 am
by veefa
here are some pics
crank breather hose ???
has crack cant find replacement. note there is no fuel in airbox or this hose now..
hole in exhaust it does look factory as there is no rust or drill damage, just a bit of grime.
it only leaks water on very hot days , I was just concerned as of the other issue ???.
reading another thred is this correct fuel / breather hose set up??
kierans Question re HRC fuel tap kit A = no stock OEM fuel tap etc..
cheers for help guys and gals
veefa
Posted: Mon Jan 27, 2014 3:02 pm
that is indeed condensation drain hole.. most Honda exhausts have somethign like that in them.
as for the breather hose.. that most likely recirculated gas mixed with oily shit that looks like petrol... nothing to worry about unless theres masses of it.
perhaps water in the fuel.. some isopropyl alcohl in the tank will help the water mix with the fuel and burn off if its in small amounts, (providing you dont let it all build up and try to flush it through)
Posted: Wed Jan 29, 2014 12:48 am
by veefa
Cheers NEO
I have isopropyl in the gallons, And I shall give tank a quick rinse out with it.
it started this morning and ran fine, no bogging down like the other day.
fwwwwuuuuuueeeew.
cheers
veefa
