cylinder head stuck nc30
rubenastley
Hey guys, i posted a while back about this and havent had time to sort it out.
I've followed the HAYNES guide and the rear cylinder head is stuck.
I removed the carbs
I removed the left and right frame bolts that hold the head in place, also the 16 bolts after taking out the cams.
In total i have remove 18 bolts in total and the carb unit. Am i missing something?
I removed the carbs
lukemillar
Re: cylinder head stuck nc30
Stupid question - Have you removed the cam carriers?
There are bolts in the V - they hold the gears from crank to cams - check for that one - Unless it is on the front head and I am making it up..
but in the middle of the V - covered in shit - a bolt!
Also - give it a tap with a rubber mallet - they are stuck nicely, as you would expect.
rubenastley
thanks for the reply but the cam carriers are removed.
CMJMJ1, legend... i totally skipped a whole paragraph on the haynes manual and did not remove the bolt in the V of the engine. Apparently i have to remove the water pump as well?
Don't have to touch the water pump if you are only removing the head..
Legend, well, I do try!
Keep us posted on how it goes...
- vfrman
- Bike owned: NC30, 1098s
You might have to remove the water pipe in the v if you can't get to the bolt with a spanner. Also...this is a stupid question, but I take it you removed the exhaust manifold, right?
