NC21 24/30 parts compatibility.
neptune
Hey,
Does any one know if the fuel tank breather valve assembly, brake and clutch levers, brake disc bolts, fuel filler cap bolts and exhaust systems are interchangeable between the models and which other Honda models share the same parts? I have an NC21 VFR400Z.
Re: NC21 24/30 parts compatibility.
Ooh awesome, I had the sales brochuer for one of those arrive in the mail today ^_^
I'll let you know when i've scanned it if it'll be of any interest to you.
400Z is an unfaird NC21... I want the bellypan & headlights for my project :D
I have the parts book here for that bike if you need anything...
fuel tank breather valve assembly -> Will check the parts book, NC24 is Identical, not sure on 30
brake levers -> NC21 and NC24, copies are widley available, NC30 adjustable ones fit.
clutch lever -> Bike has hydraulic clutch so NC21 lever. possible VFR750's too.
brake disc bolts -> NC21 / 24, also widely available.
fuel filler cap bolts -> Practically all honda models to current day.
exhaust systems -> NC21 only, very expensive. VERY hard to find.
http://www.davidsilverspares.com" onclick="window.open(this.href);return false; are your best bet.. they carry all of the parts you listed, they even had a NC21 exhaust in, serach by model and put in NC21
