Carb I.D.
Carb I.D.
I picked up this set of "SP" carbs as spares. They have the tps sensor and all the other identifiers of SP carbs. What is throwing me off is they measure 32.5-33mm. You can see the taper on them; they start out at 35mm but taper down to 32mm. Going over the workshop manual it show all SP's with 35mm although the model of 35mm carb changes with the 94. What gives?
