86 1wg genesis swingarm bearing sets
t-rex
Post by t-rex »
Sorry to be such a pain on here, but could anybody tell me where i can get a set of swingarm bearings ect for my 86 import :pray:
willandrip
Re: 86 1wg genesis swingarm bearing sets
Post by willandrip »
Don't worry about asking questions on here; its what we do.
Bearing: 93320 32403.
here; http://www.ebay.co.uk/itm/Swingarm-Need ... _531wt_758.
Bush; 33M 22184.
You may search for that at your leisure. :grin:
Try your local dealer with the part number ;you may be surprised.
Handy tip;copy the part number exactly as shown on the parts label from a Google image search to quote to a dealer.
33M 22184 becomes 33M-22184-00-00.
Often dealers computers do not recognise the abbreviated part number.
You will get the bearings much cheaper from a bearing distributer if you give the bearing dimensions/they will not recognise the Yamaha part number though.The bush is a factory part only.
t-rex
Post by t-rex »
Thank you very much for the information. I'll give my local dealer a try,one more question can i fit a 160x60x18 to my genesis rim
willandrip
Have a look at this recent thread;
viewtopic.php?f=35&t=45212
150 is about max for your rim.
If you could get a 160 to clear the chain run then you should really go up with the front tyre to balance out the handling.
You wont get any more usable grip out of a much wider tyre and you will effect the response of the 400 .
