Rocker cover bolts (torque and order)
lukeinorbit
- Bike owned: Suzuki GP 125, Yamaha FZR 1WG
Re: Rocker cover bolts (torque and order)
Is this just the rocker cover ? Have a look in the "Document Library" the link is at the very top of this page. There's a setup guide there with torque settings in.
There are gaskets on ebay, I bought a set which is expensive but if youre doing the top end you need some of the other stuff too.
Oh - you torque up in a cross pattern from the middle out. Do them up 1/2 to 3/4 first then finish them off.
lukeinorbit
Thanks Not so-Evilchicken! i cant find anything in the document library :/ i'll just have to keep scouting around for info! cheers!
OK - the FZR600R Maintenance Specifications (page 12) and page 39 of the 3TJ2 Service Manual give the info as
Cylinder Head Cover Bolts - M6 - 8No - 10Nm
These doc are here http://www.400greybike.com/docs.htm
They don't list a sequence so as I say just use a cross pattern, and tourque them 3/4 then full torque, it's quite a light setting.
