Difference between VFR400 and VFR400RR
85Coupe
Post by 85Coupe »
Hello,
What exactly is a VFR400 RR?
My newer bike says VFR400RR on the side?
What does the RR imply over a normal NC30? Race replica?
I have seen that the rear shock is different on the RR, it has a integrated 'damper', is yellow instead of red and the bike is alot higher than the normal one.
Is this a factory spec?
Thanks.
jim157
Admin NWAA
Admin NWAA
Bike owned: A few small ones
Re: Difference between VFR400 and VFR400RR
Post by jim157 »
Honda didn't make a VFR400RR. Check this thread and the VSource site out to see all the different variants manufactured by Honda:-
viewtopic.php?f=22&t=33259
http://www.vsource.org/VFR-RVF_files/BModelinfopage.htm
AUTOEXEC.TWAT
What he said ^^
They are all the same - there is no "special" spec.
1989 bikes had damper rod forks and a non remote res shock
1990 onwards had cartridge forks and a remote res shock.
scubasteve
Bike owned: 2xNC30's
Post by scubasteve »
On my v5 it says the nc30 I own is an R3 model. Does the R3 part represent it's a 1993 model or something else?
jim157
Admin NWAA
Admin NWAA
Post by jim157 »
scubasteve85 wrote:On my v5 it says the nc30 I own is an R3 model. Does the R3 part represent it's a 1993 model or something else?
I'm pretty sure all NC30's had the R3 suffix: R3K for the 89 model and R3L for the later models. I assume the '3' comes from the NC30 being the third generation of the VFR400 series, after the NC21 and NC24.
AUTOEXEC.TWAT
What he said :)
(I got your back Jim! )
jim157
Admin NWAA
Admin NWAA
Post by jim157 »
Ha!
AUTOEXEC.TWAT
JZH
Bike owned: RSCBRRVFVFRST
Post by JZH »
jim157 wrote:
scubasteve85 wrote:I'm pretty sure all NC30's had the R3 suffix: R3K for the 89 model and R3L for the later models. I assume the '3' comes from the NC30 being the third generation of the VFR400 series, after the NC21 and NC24.
Sounds good to me! That and the "No." vs "Type" thing I never have figured out...
Ciao,
JZH
London, UK/So.Cal., USA
www.vsource.org
85Coupe
Post by 85Coupe »
Why does my 89 have a 18inch rear wheel with remote res shock, and my 2003 a 17inch rear wheel with no remote shock?
Both rear wheels are centre nut type VFR wheels?
My 2003 also has a different exhaust setup where it goes 4 into 1, not 4 into 2 into 1?
Are these aftermarket mods?
krisztian_andre
Bike owned: MG v35 II, NC30, MG NF Mil.
Post by krisztian_andre »
85Coupe wrote:Why does my 89 have a 18inch rear wheel with remote res shock, and my 2003 a 17inch rear wheel with no remote shock?
A 2003 vfr400?
