NC30 CARBS ON A VFR750 ENGINE?
Jac-al
Hi,
Will NC30 or NC35 Carbs fit on a 750engine?
From what ive seen they look pretty much the same besides the stacks
Re: NC30 CARBS ON A VFR750 ENGINE?
I'll stick my neck out and say no as id bet the spacing of the inlets is different, that and i bet the 750 will need more than 32mm carbs
Jac-al
Just found out the 750 throttle bore is 36mm, so its a no, thanks
Not really throttle bore that is the problem, but more like distance between bore centres of the motor - it is wider between the inlets.
Morespeedvicar
I do wonder why more racers dont use 750 carbs on nc30's, you wouldn't think it'd be that difficult to narrow them a bit.
Because 36mm is a tad to big for a 400 I reckon
krisztian_andre
- Bike owned: MG v35 II, NC30, MG NF Mil.
Maybe an oversized bore would lower the pressure difference at the jets and could cause problems with fuel atomization.
