spark/electrical prob or fuel prob
badger4543
So previously I posted about my nc30 have a fuel problem. Thought I cured it. Then this morning on the way to work I copped aanother issue. At around 5-6k big bogging and crackles from the exhaust I thought it might be electrical as the tachometer does weird jumping and diving action when it happens as the previously it would still rev out just have a flat spot. Any ideas?
dobbslc
Re: spark/electrical prob or fuel prob
The tach usually takes a signal from the coil feed so if you're losing that it might be the ignition pick up that's iffy.
badger4543
Ignition pick up? Plz explain lol. As in like that stator? Or just a plug off the ignition some where. It's like over a certain rev the ignition gets cut.
Morespeedvicar
Hi, is your speedo working? Could be going into limp mode?
badger4543
Speedo still was working.
badger4543
problem fixed one on the plugs of the cdi must of been loose in the end it came completely out and bike stalled..but couldnt get my fingers to it had to call a mate to come with screw drivers..
tach wire comes out the ignitino box on the vfrdobbslc wrote:The tach usually takes a signal from the coil feed so if you're losing that it might be the ignition pick up that's iffy.
