Page 1 of 2
cbr 400rr splutters above 6000rpm help
Posted: Wed Oct 09, 2013 4:45 pm
by rochie
hi all
in need of your help my cbr400rr nc29 is running crap !!!!!!!
as soon as I get to 6000 revs it just splutters
ive balanced carbs properly using vacuum gauges ive put brand new jets in (standard) a kit from NRP CARBS.new plugs
and its the same
can any one help me in urgent need got a track day on Monday !!!!!!!!!
Re: cbr 400rr splutters above 6000rpm help
Posted: Wed Oct 09, 2013 7:09 pm
by vr46
5500 RPM restriction?
Does it rev and drive above 6k? if not then the problem may be with the speedo wiring.
Posted: Wed Oct 09, 2013 9:56 pm
by rochie
hi thank you for replying
yes it drives but very very poor it just splutters and it feels like the throttle is rolling on of so to say
Posted: Wed Oct 09, 2013 9:57 pm
by rochie
please help
Posted: Thu Oct 10, 2013 9:33 am
by vr46
Not sure really...
Maybe it's worth draining / flushing the petrol tank and cleaning the fuel tap filter? There is also a secondary filter on the fuel tap outlet...
Posted: Thu Oct 10, 2013 10:25 am
Have you got a speedo plugged in?
If not, plug it back in
Posted: Thu Oct 10, 2013 10:51 am
by rochie
hi yes all plugged in
Posted: Fri Oct 11, 2013 12:43 pm
by rochie
hi all got it sorted
the tps was out also removed K&N filter and put original in
also removed the filter before the the pump and replaced it and rebalanced carbs
runs 100% better now hits the redline no probs customer very happy now hope this info can help anyone else
Posted: Sat Mar 15, 2014 11:45 pm
by gareth91
hi, i have a nc23 cbr and around 6000rpm it sputters for a split second then will rev on up. only happens around the 5-6000 mark. What does tps stand for?
Posted: Sun Mar 16, 2014 8:54 am
by leopard_pagan
Throttle position sensor
