Rs125 seat unit on a nc30?
				talcumpowderbut
Hi guys, So seen this advert for a nc30 on ebay. And asked the guy what seat unit is on the back. He said a honda rs 125 fairing. Do you think it would take alot of modification to get it fitted. I personally think it looks quite good even if the bike is not in the best condition
Here is the link
http://www.ebay.co.uk/itm/Honda-VFR-NC3 ... 4aca1b0903
And here is a pattern seat which i would use if it is not too much hassle.
http://www.ebay.co.uk/itm/HONDA-RS-125- ... 43b77c18ca
Cheers connor
						Here is the link
Cheers connor
Re: Rs125 seat unit on a nc30?
Anything can be made to bolt on with enough work.
The bike on ebay has a custom subframe by the looks of it, you'd have to chop a lot off the standard one to fit the rs seat unit, then more work to get it to bolt up properly. It doesn't look like a standard battery tray would fit either.
Making a custom subframe from alloy box section would be the easiest way to get it to fit properly.
				talcumpowderbut
Cool cheers for the info. Would one of rick olivers custom subframe work do you think?Cammo wrote:Anything can be made to bolt on with enough work.
No as thats to fit a standard seat unit, you need a subframe made to fit which unless you can weld isnt going to be cheap.
				talcumpowderbut
Cool will look into it cheers. connorDrunkn Munky wrote:No as thats to fit a standard seat unit, you need a subframe made to fit which unless you can weld isnt going to be cheap.
