NC30 Gearbox help required (PLEASE HELP)
Posted: Wed Oct 22, 2008 9:48 pm
by Cog Head
hi, my nc30 gear box is a little ill... it like to jump out of gear in 1st when i take it over 7K ish, but is fine in all other gears.
iv found 2 sets of gearbox internals for a reasonable price, but id not know where to start when it comes to getting the old bits out and the new bits in. iv spoken to my local stealer, and they wont touch it.
dose anyone know any where that will do it in the midlands or anyone who will do it or come help me.
or wold it be a waste of time? there are a few wngines on the bay at the moment.
Re: NC30 Gearbox help required (PLEASE HELP)
Posted: Wed Oct 22, 2008 9:51 pm
by wullvfr
selector forks may be worn,gear grooves worn.
also the gear dogs or dog slots worn.
william
Posted: Wed Oct 22, 2008 9:54 pm
Have a look in the Haynes mate - if it makes sense then get some time and get stuck in. I can also email you a service manual if you want it - it might give you additonal info to make the decision on it
You don't have to split the cases apparently so you can do it if you are careful.
For the cash and the experience/satisfaction I would be getting into it.
Posted: Wed Oct 22, 2008 9:59 pm
by Cog Head
i have the hanyes manual and he tells me to split the cases... if that needs to be done then sod it ill buy a new engine.
so i can get to the box by fliping the engine and removing the sump... i dont understand how id then get the gears out :S are they not attached to bothsides of the case's?
thanks for the replys so far, keep em coming :D
Posted: Wed Oct 22, 2008 10:10 pm
by fastdruid
If you can get a decent engine cheap enough then it's easier to do that as you will have to split the cases to fix it, you can do this without touching the top end if you are careful.
You need to take the engine out no matter what you do and you'll either need to do the work yourself[1] or pay for someone to do it plus of course get the bits.
FWIW when our NC35 started to do this I got a far lower mileage (21kKm instead of 55kKm) engine and carbs for 120quid...
Druid
[1] How much do you value your spare time?
Posted: Wed Oct 22, 2008 10:19 pm
by Cog Head
i dont really have the time or space for it to be a sime and space consuming job.
im selling it soon, the only reason i want the gerabox done is so i can sell it, i doubt id get anything for it with a dead box
