Page 1 of 3
Help me get my Air/Fuel mixture right! PLEASE!
Posted: Sun Sep 29, 2013 4:10 am
by vfrman
So today I took my track bike into PJ's Motorcycles to get a baseline done on the dyno. I am running very rich, and I have that nasty dip at 5k.
I'm running 118 front 120 rear on the mains, 35 pilot all around, 4 hole emulsion tubes front and 5 hole rear, stock airbox with K&N element, and an aftermarket exhaust. I also looked at the needles and I'm running something aftermarket. It is the gold one in pic set at the third position. I also have a set of the silver needles in the pic, but I'm thinking that with the bike running as rich as it is, maybe I don't want to put those in just yet. I'd like to get the fueling spot on, then later on put the HRC setup in from Rick O and see what difference it makes.
Anyways, on to the pics of the needles and dyno sheets...
Also, WTF is happening at the top end of the rev range?
Re: Help me get my Air/Fuel mixture right! PLEASE!
Posted: Sun Sep 29, 2013 4:33 am
by johnnie5
i reckon you have a issue with missfiring at the high RPM
bad plugs or something else
Posted: Sun Sep 29, 2013 4:54 am
by vfrman
Those plugs are pretty new...but with it running that rich they are probably fouled.
Posted: Sun Sep 29, 2013 7:55 am
by krisztian_andre
Does it burn oil, what was the altitude, temperature and humidity, do you have a strong spark, were the carbs cleaned, float levels set and float needle valves checked?
Other than that it's probably a good idea to get a set of road needles from rick and start with those and standard sized jets.
I forgot the pilot screw check.
Posted: Sun Sep 29, 2013 7:59 am
by magg
IMHO a needle change would not make much difference, the top end mixture is a main jet function. Restrictive air filter will cause over-rich mixture that could be significant at the top end of the rpm range, are K&N filters as good as OEM (you can get OEM filters from PowerSportsPlus, bought two last week). May be remove the K&N filter and see if the mixture become leaner, might still not be perfect but could head you in the right direction.
Posted: Sun Sep 29, 2013 11:43 am
by hunter
magg wrote:IMHO a needle change would not make much difference, the top end mixture is a main jet function. Restrictive air filter will cause over-rich mixture that could be significant at the top end of the rpm range, are K&N filters as good as OEM (you can get OEM filters from PowerSportsPlus, bought two last week). May be remove the K&N filter and see if the mixture become leaner, might still not be perfect but could head you in the right direction.
Posted: Sun Sep 29, 2013 11:57 am
by Yakama
Those needles look like factory pro ones
Posted: Sun Sep 29, 2013 4:24 pm
by vfrman
krisztian_andre wrote:Does it burn oil, what was the altitude, temperature and humidity, do you have a strong spark, were the carbs cleaned, float levels set and float needle valves checked?
Doesn't burn oil, altitude is 5300 feet ASL, temp was 71 F (21.6 C), 13% humidity. Spark should be strong, but with the bike running that rich, the plugs may be F-ed. Carbs were clean, floats were a touch high...maybe 7-8mm instead of 6.8mm, float needles were good, and pilot screws set properly.
I know this doesn't do anything for fuel metering, but I think the hole in the slides is still std. What diameter do we drill those out to again?
Posted: Mon Sep 30, 2013 12:35 am
by Morespeedvicar
I'd try n put it back to standard jetting and see what happens, i wouldnt of thought the filter would make it go rich.
Ian
Posted: Tue Oct 01, 2013 5:09 am
by vfrman
It IS set to standard jetting!
