Another NC30 Shim post
Posted: Sat Sep 21, 2013 8:46 pm
Hi folks, i'm sure you've all seen posts about shims before. I measured all mine up and the gaps etc. Ordered my new shims and well... the two of the inlet valve shims, where i should have a .13mm clearance after having calculated it (or so i thought!), i can't get the .13 gauge in. i can however get the .10mm gauge in and it feels quite loose.
Not tried to start the bike yet as i've got other work to do to it first, but just thought i'd ask..should i get slightly smaller shims so that i can get to about .13 or .15? Or will i be ok?
All the other shims are within the tolerance set out in the haynes manual.
Cheers.
Cheers.
