30 / 35 riders, lack of cush-drive question.
Since I now have my forks and clutch system sorted out for the 24 i'm starting to focuson the rear now
My original plan for the rear was to a the VFR750 wheel with the use of spacers to avoid hitting the chain and move the linkpipe a tad.
However, I was looking at a 30 hub assembly today and i'm sure it'll fit straight into the 24 swinging arm as it looks practically identical, but if not I can get a complete NC30 rear-end for pennies, with hub / shock too ^_^
While converting it to a 30 style rear would be one way to go i'll loose the cush-drive of the 24
Both are gonna cost me pretty much the same in the end, does having the lack of cush-drive on the later models affect the wear and tear rate much? ie chain / sprockets / wheel bearings? as from my understanding the cush-drive is there to reduce stress by acting as a dampner.
Re: 30 / 35 riders, lack of cush-drive question.
Yep - the chain on a 30 takes a beating but I feel that it cannot be that bad. a 525 size on a bike this small must be decent enough.
It may be, for a shot in the dark, that the sprag clutch lessens some of the absloute shock loads the chain would have with no cush drive.
I wonder if part of the reason is that the NC24 is 180degree while the NC30/35 are 360degree.
Druid
Druid
Interesting... hadn't considered that train of thought. The 24 also has a 525 chain so i dunno why it was left out of the 30/35 model.fastdruid wrote:I wonder if part of the reason is that the NC24 is 180degree while the NC30/35 are 360degree.
Druid
It doesn't weigh all that much and considering i'm no rossi (as you'll probably find out on the next 400 trackday :D) I might just leave it there and go the original plan of the 750 rear wheel.
thanks for the suggestions... does no one else have anything cooking atm besides me?
The nc30/35 has a sprague clutch that acts as a kind of slipper clutch, this may reduce the wear of not having a cush drive. Does the 24 have this?
Chain wear is not too bad on the 30 imo (it does take some punishment though), but if left unattended will reduce the life considerably. Same as any bike I guess.
Er yes but not for a 400.Neosophist wrote:thanks for the suggestions... does no one else have anything cooking atm besides me?
Actually more a simmer atm because of the 400's really.
I've bought more bits for my RC24 project[0] and thanks to Zimm I have a nice programable CDI for my SV650/700 on-going project[1] but the 400's are pretty standard. Well apart from the carbon fibre bits anyway!
Actually I suppose the NC24 frame looks rather like the RC24. :D
Druid
[0] I'm putting a CBR600RR5 rear end and R1 frontend on it.
Have all the bits for the rear end, just need R1/R6 calipers, a front wheel/discs, a mudguard and some kind of remote res clutch master cylinder. Then a bit of time on a lathe...
[1] USD forks, 6 pot calipers, alloy subframes, GSXR fairing, OSF rearsets, akrapovic exhaust, lots of crash bungs...
A sprag clutch is a one way clutch typically used for the starter. I'm pretty sure the NC30/35 doesn't have one in any other function.Stickshift wrote:The nc30/35 has a sprague clutch that acts as a kind of slipper clutch, this may reduce the wear of not having a cush drive. Does the 24 have this?
http://en.wikipedia.org/wiki/Sprag" onclick="window.open(this.href);return false;
Druid
- Jon
The 180 degree firing split will be easier on the chain than the 270/90 degree split of the NC30/35 as it is more even.fastdruid wrote:I wonder if part of the reason is that the NC24 is 180degree while the NC30/35 are 360degree.
Druid
The slipper clutch only has an effect under engine braking and no effect when powering on.
regards
jon
Aah.. that rear-end looks like the gullarm rear-end.fastdruid wrote:Er yes but not for a 400.Neosophist wrote:thanks for the suggestions... does no one else have anything cooking atm besides me?
Druid
as for the NC24 frame...
Quite similar I thinks..
-edit-
bored much...
Oh and while i was browsing some specs earlier came across this...
VFR400R(NC24) Overview : Change rear swing arm to PRO-ARM.
(Apr,'86) Max. H.P. : 59PS / 12500rpm
Tolque : 4.0kg-m / 10000rpm
Size : 2010mm(D) x 690mm(W) x 1125mm(H)
Wheelbase : 1375mm
Dry weight : 164kg
Front wheel : 100/90-16 54H
Rear wheel : 130/70-18 63H
Price : 679,000yen ($7,988)
VFR400R(NC30) Overview : The first model of NC30. All parts are
(Dec,'89) renew. With 360 degrees crank.
Size : 1985mm(D) x 705mm(W) x 1075mm(H)
Wheelbase : 1345mm
Dry weight : 182kg
Front wheel : 120/60R-17 54H
Rear wheel : 150/60R-18 67H
Price : 695,000yen ($8,176)
VFR400R(NC30) Overview : Suspention changed(front/rear)
( ,'91) Max. H.P. : 59PS / 12500rpm
Wheelbase : 1345mm
Dry weight : 185kg
Price : 719,000yen ($8,459)
20kg lighter!!
It does use one in the clutch function.fastdruid wrote:A sprag clutch is a one way clutch typically used for the starter. I'm pretty sure the NC30/35 doesn't have one in any other function.Stickshift wrote:The nc30/35 has a sprague clutch that acts as a kind of slipper clutch, this may reduce the wear of not having a cush drive. Does the 24 have this?
Not typically a true slipper clutch by todays standards, but like Jon said it eases pressure on teh clutch under heavy engine braking.
