Tooling Up
Posted: Tue Oct 21, 2008 3:41 am
by dx400r
Right guys and gals - I have a pretty reasonable toolkit as it stands. Socket set, screwdrivers etc.. but with my NC30 facing possible spinal/frame damage (looks okay but looks can be deceiving) im looking to grab hold of what I am going to need to build mine up from a bare frame should it come to that.
What special tools would I be needing? And how do I get them without being crippled for the privilege?
I already have:
:arrow: Chain Adjuster
:arrow: NC30 Plugspanner
Thanks in advance all,
dx4
Re: Tooling Up
Posted: Tue Oct 21, 2008 7:28 am
by Jon
For a frame swap on a NC30 the main tools other than garden variety wil be the castle spanners for the engine mounts and swingarm pivot bolt.
There was someone on the old forum making them, they are nearly always on eBay or you may be able to borrow them off someone cnearby.
regards
jon
Re: Tooling Up
Posted: Tue Oct 21, 2008 10:25 am
by Smev
Rick Oliver Also sells the genuine Honda ones which will do the frame and swing arm :)
Re: Tooling Up
Posted: Tue Oct 21, 2008 1:24 pm
by Spike16
if you need any tools i can get some from work for you at discount price, im thinking of quitting soon :o so am looking to take advantage of the discount as much as possible before i go!
thats an open invite to anyone that wants stuff from halfords (within reason)
Re: Tooling Up
Posted: Tue Oct 21, 2008 2:04 pm
by dx400r
Smev wrote:Rick Oliver Also sells the genuine Honda ones which will do the frame and swing arm :)
If these are genuine Honda items them wont they be silly money or can Rick do magic? :D
This sounds interesting Spike what sorta price can you get me on (not sure of sizes, so I hope you or others know):
Socket for Yoke Nut
Socket for Hub Nut
Socket for Wheel Nut
Decent Torque Wrench
Jacks
What do people recommend for getting an NC30 up in the air in a fashion that allows it to be worked on easily? Seen someone supporting theirs with jack somehow along with some axle stands. ABBA stands a worthy investment?
Re: Tooling Up
Posted: Tue Oct 21, 2008 5:24 pm
by fastdruid
dx4 wrote:What do people recommend for getting an NC30 up in the air in a fashion that allows it to be worked on easily? Seen someone supporting theirs with jack somehow along with some axle stands. ABBA stands a worthy investment?
Cheap one is to put axle stands under the footpegs and a jack under the engine.
Works better with rearsets than original footpegs but does still work (you just have less to locate the stands).
Druid
Re: Tooling Up
Posted: Tue Oct 21, 2008 8:26 pm
by Spike16
i went in today and the socket for the rear wheel is a 36mm impact socket (£9.50 normally) and the decent torque wrench is ($49.99 normally) came out as £45, we only do sockets up to 38mm so you'll need to source the top yoke nut one and hub nut (dont know the size but pritty sure its more than 38) seperately
are you interested?
Re: Tooling Up
Posted: Tue Oct 21, 2008 8:39 pm
by wullvfr
for any large size sockets try http://www.toolshopdirect.co.uk" onclick="window.open(this.href);return false;
type in the search bar 41mm socket and it comes up with loads,i always go for the cheapest which usually is the good side of a tenner.
i bought a 46mm socket for under a tenner BARGAIN!!!!
william
Re: Tooling Up
Posted: Tue Oct 21, 2008 8:50 pm
by fastdruid
I've used http://www.cromwell.co.uk/" onclick="window.open(this.href);return false; for tools before, seem reasonably priced and even phoned up to check I'd received what I ordered.
Druid
Re: Tooling Up
Posted: Tue Oct 21, 2008 10:46 pm
by Brainchild
I've been using my Brittool torque wrench for many years now and I have to say its never put a foot wrong, even tho I abuse it terribly (I use it as a tightening wrench for torques much higher than its maximum measurement, as its the longest handled wrench I have). I got it from my dad and know it was about £75 4 years ago, so may be more now, and I think theres lots of sizes available.
