3tj rear caliper
fzrtim
Bike owned: FZR400 FZRhybrid FZR600 RSV1k
3tj rear caliper
Post by fzrtim »
Just got stuck into my latest project and the rear caliper is siezed solid. Think it will be easier/cheaper to replace it rather than strip it and replace the pistons.
Does any one know if the same rear caliper is fitted to any other models or if any other calipers will fit.
Cheers Tim
oollit
Bike owned: FZR400RR 3TJ, RF900R
Re: 3tj rear caliper
Post by oollit »
Wemoto do a stainless steel piston and seal kit for £40 and a seal kit for £15.
I put the stainless pistons kit in my 3tj and it transformed the rear brake.
I don't know if ant other calipers fit the 3TJ but even if you find something else, it will probably need overhauling before you fit it anyway.
It would certainly be worth ripping your caliper apart to see how bad it is before you spend any money.
I only please one person per day.
Today is not your day, tomorrow isn't looking good either.
sharpey
Post by sharpey »
another good place to try is hi-level
fzrtim
Post by fzrtim »
The pistons are rusted in place and really i dont even want to try to strip them. They have been a problem pre the bike standing for 2 years as the disc has worn to 50% of its thickness. I tried to move the piston with a big pair of water pump pliers but the pads bent and still they didnt move! I then tried to pump the pistons out using the pedal with the caliper removed but still no movement.
The front calipers however are fine.
spannerman
Post by spannerman »
i have fitted a gsxr 1000 k3 rear calliper to my 3tj an its a straight fit with no tweeking
also feels good on the peddle an looks the dogs
Post by Evilchicken0 »
I know a lot of rear calipers look very similar as it's a Brembo.
Spannerman can you post a pic or link to one
