1WG Link Pipe
Posted: Fri Aug 09, 2013 9:17 am
by Evilchicken0
I bought a can and link pipe but it's not a 3TJ one, it's the right diameter but the can just sits in the wrong place. The link pipe has a single bend in it where the 3TJ's has two.
Could somebody with a 1WG and aftermarket pipe take a pic from above and the side for a comparison ???
Re: 1WG Link Pipe
Posted: Fri Aug 09, 2013 10:24 am
by willandrip
Probably would have been better removed ;
Cobra;
Micron;
Hope they are of some small help.
Re: 1WG Link Pipe
Posted: Fri Aug 09, 2013 1:25 pm
by Evilchicken0
Could be ... so 1 bend ... I'll get a pic of this link pipe
Re: 1WG Link Pipe
Posted: Fri Aug 09, 2013 8:36 pm
by levo
If you can wait boris I have a spare 3tj link pipe you can have
I'll be back off my hols a week Monday
I'll pm you my mobile no
Re: 1WG Link Pipe
Posted: Fri Aug 09, 2013 8:44 pm
by Evilchicken0
Sure thang :)
Re: 1WG Link Pipe
Posted: Sun Aug 11, 2013 7:13 pm
by Evilchicken0
Here you go - is the a 1wg ?
Re: 1WG Link Pipe
Posted: Sun Aug 11, 2013 7:34 pm
by willandrip
Well it looks like one :whistle: ,you have a bit leeway when fitting as you well know. ;)
Seems a bit short if can has intergral 2 sliding bolt mounts; if its a wrap round strap you can alter it more.
Looks like a later Micron by the rubber seal ?
I fitted a fzr1000 aftermarket can (Renegade read Reject) and link to the first 3EN2 I did; it fitted but the link pipe was never quite right though. :down: sharp got replaced!
That Cobra is strictly speaking a 600 unit but it fits the 400 spot on.
Re: 1WG Link Pipe
Posted: Sun Aug 11, 2013 9:52 pm
by Evilchicken0
I think its a Lazer can the strap was from a 3tj but doesn't fit it very well ... and I doesn't fit my 3th at all
