Hi guys me again lol exhaust studs and nuts ?
chris6409
Post by chris6409 »
Right ive acquired downpipes thanks to kayla and i was hoing to replace the head studs and the flange nut that was untill i discovered they where going to cost me £48 now im not tight but £50 on nuts and bolts is crazy
Hmm my question to you helpful bunch is. Is there an alternative to these crazy priced nuts ???
Re: Hi guys me again lol exhaust studs and nuts ?
Post by Evilchicken0 »
Flange bolts ... Its M6 but I don't know the length.
pearson*
Bike owned: FZR400RR
Post by pearson* »
i just did mine recently, got a few nuts spare. il check the length of the studs in the morning for you
willandrip
Post by willandrip »
A search returned this item in 1.26 seconds;
http://www.ebay.co.uk/itm/Scooter-Moped ... 1270wt_992
Use the nuts/discard the studs.
EDIT ;The link is included as these nuts are very similar to the original .
rockTJ
Bike owned: GSX650F FZR250x2 RSV RG80
Post by rockTJ »
I've just ordered a full set of Yamaha studs/nuts/exhaust gaskets for my FZR250, I'm sure the nuts were £2.05 each.
Part number 90179-06500 on both 3LN and 3TJ's
Chris
Morespeedvicar
Post by Morespeedvicar »
Stainless m6 threaded bar and 8 m6 nuts? or 8 m6 stainless bolts and chop there heads off? Will never rust again......
Have a look on ebay fittings are mega cheap on there!
Ian
chris6409
Post by chris6409 »
Thats what i was thinking plus stainless deals with head much better
chris6409
Post by chris6409 »
What is the reason for the part in the middle of the nut without thread ?
Morespeedvicar wrote:Stainless m6 threaded bar and 8 m6 nuts? or 8 m6 stainless bolts and chop there heads off? Will never rust again......
Ian
You can buy stainless studs on the bay.
You mean in the ebay link ??? The stud is 2 different sizes 6mm one end 7mm the other, the thread stops and starts where they change from one to the other.
chris6409
Post by chris6409 »
So 6mm one side and 7mm the other and is it the 7mm that goes into the head also will the stainless be an issue ?
