73a pilot jet settings!!???
Posted: Mon Oct 20, 2008 1:20 pm
hi there,
Is there are standeard setting for the piolet jet screws that control the low runnign of my gsxr? Recently stripped the carbs to clean out a sticking float and while being distracted by the missus in the kitchen started to undo the screw for the jet on either cylinder 2 or 3 instead of the screw that holds the float bowl on
i tryed to guesstimate where it was and screwed it back in but my memory isn't to sharp. since i got it all back together it nedd the throttle pinning with my finger on the starter for about 5 secs before it picks up, and on the road splutters and bangs untill it hits 6500-7000rpm when it smooths out and runs faultlessly. Is there a way to set the pilot jets up or at least a base setting i can start from??
Thanks for reading the post and thanks in advance for any replies
