NC30 headlight bulbs!!??
- Cal Walker
- Bike owned: NC30, CRF450R Supermoto
Hey guys,
Really silly question
What headlight bulbs do I need for my NC30? It's a jap NC
What headlights bulbs?
What side light bulbs?
If anyone can help, I would be very grateful
Regards.....Cal
Regards.....Cal
Re: NC30 headlight bulbs!!??
H4R 35/60 for the proper lights.. no idea on the sidelights.. T10 rings a bell...but someone will tell you in a minute
BIKERMANLALLY
- Bike owned: VFR400 NC30(1991)
JAPAN SPEC: Headlight 60/35 W halogen x2-(means bulb qty)
UK SPEC: Headlight 60/55 W halogen x2
JAPAN SPEC: Sidelight 1.7 W X2
UK SPEC: 5.0 W x2.
Found in Haynes Manuel 9.2 Electrical System.
UK SPEC: 5.0 W x2.
- Cal Walker
Does one of theses bulbs fry the wiring or something? I've heard on it here the something like that?
I went to test them yesterday, so I just turned the ignition on to see and they worked, then I tried them again with just the ignition on and they didn't work!? Don't know if I've blown the bulbs from doing it in quick succession.
So where can I get some 60/35 bulbs from? And are they a H4? As mines a jap import
Regards......Cal
Regards......Cal
Jap are H4R 35/60
it is fitting H4 55/60 that fry the switchgear
- jim157
The Japanese market bikes use H4R bulbs, UK bikes use H4 bulbs. You can use H4 bulbs but you'll either have to modify the bulbs/housing or use adapter rings like these:-
You'll also have to perform the headlamp relay mod which is detailed in the document section:-
http://www.400greybike.com/docs.htm
AUTOEXEC.TWAT
- Cal Walker
Right just been out to the bike to whip the bulbs out my left one had the proper 12v 60/35w bulb in and the right one had a 60/55w in, as some knob has put it in before and just bent the tab back!
So where can I find some 60/35 bulbs ideally?
Regards.....Cal
Regards.....Cal
I get mine from my local bike shop...simples.
Local bike shop, Honda / Kawaski dealerCal Walker wrote:Right just been out to the bike to whip the bulbs out my left one had the proper 12v 60/35w bulb in and the right one had a 60/55w in, as some knob has put it in before and just bent the tab back!
Regards.....Cal
ZXR400 also uses these.
