More NC30 carb advice, pretty please!
Posted: Sun Jul 21, 2013 7:55 pm
Hi,
Finally started to make some headway with my carb problems on my jap NC30. When bought, it would struggle to rev though 8 to 12 grand in higher gears, though revved cleanly up to there and after. Stripped carbs using cammos excellent guide, and found nothing untoward, all clean, other than some very odd needles. Jets are 118f 120r, emulsion tubes 4 hole f, 5 hole r. All jets were removed and cleaned, replaced needles with rick oliver ones and kept the single washer underneath them. Diaphragms in fine condition and all slides return evenly.
Test riding after this change now had made the full throttle higher rev problem go away, but now on partial throttle openings between roughly a quarter and half it would miss like mad, regardless of rpms, full throttle was fine.
On both instances, used fuel like mad, about 65 miles to reserve on a full tank then 75 with changed needles, and seriously sooty around the exhaust outlet. Exhaust btw is a horrible stubby viper can, originally had a db killer in, but I removed it in a simple bid to try lean it out, slightly better like this but still a nightmare to ride through corners trying to feather the throttle.
So stripped them again yesterday, all needles jets etc removed to check and clean. Checked float heights at 6.8mm or thereabouts, and idle mixture screws checked to make sure seals in place and no blockages. Set these back to 2 1/4 turns out. No different.
So today, have taken them off again (getting good at it now lol) have taken the washer out from under the needles, and turned the low end needles in an eighth in a bid to lean it out.
Now it's definitely made a difference for the better, nowhere near as bad on partial throttle as it was. Baffle is still out and would prefer to run with it in. It's not perfect, but useable now.
Question one, should I try maybe going to 118f 115r main jets?
Question two, anyone ever come across a similar problem?
Many thanks for any help or suggestions, wanna start restoring it over this winter, but not till the bugger is running to my liking!
Cheers!
Cheers!
