Removal of some fork oil?
stevie
- Bike owned: 92 uk model nc30
Hi all, I'm just putting my nc30 back on the road after a 4 year rest period, iv fitted a new batterie & done an oil & filter change & new plugs, she runs perfect, but just before she went into hibernation I had all the suspension re built with full ohlins internals, the only problem is at medium to high speed she seems to skit over the bumps rather than soak them up, iv tryed adding some rebound but it hadent made much difference, iv spoken to a suspension firm & they said try taking 10cc of oil out of each fork, can this be done by simply undoing the fork tops and drawing the oil out with a serynge or do I have to remove the whole fork, any help would be appreciated as it has caused a few hairey moments on fast corners, thanks.
Re: Removal of some fork oil?
What does it do?
Try and figure out what the fork is doing- removing some oil will not make it change the feel apart from under a strong compression and with a lot of travel being used.
Describe what the fork does - what surface? How much travel used? on brakes or throttle? in a corner?
removing oil, unless it has far too much in it, will do bugger all.
- Bike owned: VFR400
Agree with CMSMJ1, also what was actually changed, oil used etc?
