Tyre advice please :)
VFRVTEC-FZR400
Post by VFRVTEC-FZR400 »
So I'm new to the forum as have only just puchased a FZR400 1WG but seeing as it has the 18' rear tyre i'm confused as to what tyres are best to put on the bike.
I've had a look on ebay and only three of them seem suitable for the bike which are Pirelli Sport Demons, Avon Roadriders and the Bridgestone BT045 although i've never liked bridgestones
anyone got any idea whats best to stick on the bike as it will be used on the track alot as well so needs to be really grippy :)
Re: Tyre advice please :)
Post by Evilchicken0 »
For track use ... change the rear wheel to a 17"
It might sound dramatic but if you really want trackday / track tyres that's what's going to be best. If you use a swingarm and wheel from a TRX850 / FZR600R etc then you'll get a 160 profile in which is suported by lots of manufacturers. Kayla can probably advise you on what machining work needs to be done and sort you out with spacers.
You might want to find out the exact model of FZR400 you have;
No air intakes, No exup valve = Genesis (1986 -87)
No air intakes, Exup valve single seat = 2TK SP (1987)
Air intakes above the headlights, Exup valve = 3EN1 (1988) Speed restricted
Air intakes below the headlights, Exup valve = 3EN2 (1989) Speed restricted
Welcome to the forum
VFRVTEC-FZR400
Heya its a 3EN1, couple of my mates said it would be best to stick a wider rear wheel on the back and means i can stick with my love for the pirelli diablo's range :) thanks for the help
Be best to put a front end on the too, that way you can usa a 3.5" front wheel with a 120/70 front to work with the 160 back.
Kayla850
Bike owned: Sunn Tzar S2
Post by Kayla850 »
I can go one better than advising, I just happen to have a(nother) complete rear end from a 3TJ lying on the workshop floor, already modified to fit a 1WG... Oh, and a full (rebuilt with new seals and oil) 41mm front end from a 3EN2 with a 3.5" 3TJ front wheel. The wheels even match :grin:
Free* to a good home.
* Not free.
www.projection-racing.com
www.pjcfasteners.com
The 3en2 having the bigger (298mm) brake disks than the 3en1 (285mm) :grin:
VFRVTEC-FZR400
How much would you be wanting for it mate, and how much work was required to get it to fit onto the 1WG?
