NC30 rear master cylinder diameter?
Re: NC30 rear master cylinder diameter?
Yes, I do.
You can find it in the service manual with all the other specifications for the bike in the downloads section at the top of the page.
Part 1 (has all the specs and clearances straight from the manufacturer)
14mm is your answer, but next time try the document library. You can find most things there.
vfr4
Thanks for the quick and informative reply - I never knew there was a document section!!
Cheers,
Al
Cheers,
Al
Faith, hope and cable ties...
vfr4
Anyone know? need to find a 14mm rear m/c for my delinked vfr800
